Notices
How to Bleed the ABS?
Old March 1st, 2009, 8:03 PM
Leg0nd's Avatar
Default How to Bleed the ABS?
Hey guys! I am new to the forum, but am hoping that someone can tell me how to bleed the ABS brake system on my 2001 6.0 liter 3/4 ton suburban? Thanks!
Old March 1st, 2009, 9:29 PM
EvansBlue's Avatar
The same way you bleed a regular system.
Just loosen the bleeder screw and pump the brake until there's no bubbles. Refill the master cylinder after each bleed. Bleed in this order- LR,RR,LF,RF. Its a 2-man job.
Old March 2nd, 2009, 3:24 PM
Banned
shawnvw's Avatar
Here is how GM explains it.....
Hydraulic Brake System Bleeding (Manual)
Caution: Refer to Brake Fluid Irritant Caution in the Preface section.
Notice: Refer to Brake Fluid Effects on Paint and Electrical Components Notice in the Preface section.
  1. [*]
Old March 5th, 2009, 4:29 PM
Leg0nd's Avatar
thanks guys! will work on it tonight!
Old March 5th, 2009, 8:02 PM
Leg0nd's Avatar
i got bled the brakes but the stupid light still came back on and the new abs pump won't stop howling. do you have to reset the pump? what else could be right? any suggestions?
Old September 27th, 2013, 1:24 AM
Russell Emmons's Avatar
Default replaced pads
hey i replaced the front pads opened the bleeder screws , bleed them brakes spongy theres no portioning valve to equalize or is that part of the abs?
barking spider
Silverado & Fullsize Pick-ups
September 13th, 2010 8:35 PM
heavychevy63
August 6th, 2008 7:40 PM
Waltmoe
August 31st, 2007 11:33 AM
chevy3quarta
July 27th, 2007 5:19 PM
dogz46
December 9th, 2006 8:34 PM
Quick Reply: How to Bleed the ABS?
