How can I bypass factory amp
Old May 14th, 2009, 9:25 PM
95burban's Avatar
Question How can I bypass factory amp
how do i bypass factory amp 95 suburban I put a new cd player in and now the highs turn off when i turn it up then i have to turn the deck off for minit turn it back on then it works butt if i turn it up the high turn off just the subs are working any one know how to bypass the factory amp????????
Old May 15th, 2009, 6:06 AM
Impala Super Moderator
HotSauce6226's Avatar
There is alot more behind it than this. The amp is protecting your stereo for a reason. Plus, what ohm are your factory speakers?
What ohm is your HU?
Old May 15th, 2009, 3:43 PM
95burban's Avatar
Its a kenwood it works fine in my car (Loud) took it out for the Burban,,,
dont know the ohms they are stock speakers im just going to wire it up strate to the deck bypass all the bull ****,,
Old May 15th, 2009, 4:20 PM
And you will mess up your HU.
You need to know the ohms first. Unless you add an aftermarket amp
Old September 13th, 2009, 2:49 PM
durtiJ's Avatar
Sorry HotSauce6226 but you are wrong on this matter. The problem is the aftermarket head unit pushes to many volts through the factory amplifier causing it to clip. The solution should be to simply unplug the factory amplifier. BTW this isn't going to mess up your head unit.
Old September 14th, 2009, 3:32 PM
Banned
shawnvw's Avatar
HotSauce is right actually.....lets say the front doors are rated at 2ohms, and the front tweeters are at 2ohms as well.....put them together and you get 1ohm, thats enough to overdrive\overheat the headunit and cause damage.
Most headunits are made to work on speakers rated at 4ohms
Old June 19th, 2017, 7:44 PM
Monty Brock's Avatar
Default Speaker
Hi I'm having a problem with right turns and bumps cutting my speakers out, I was wondering if you could give me advice on what to do.
noxlanding
Equinox
21
October 26th, 2020 5:03 PM
Raptormann11
Silverado & Fullsize Pick-ups
February 16th, 2013 6:16 PM
nikkijdcb
May 4th, 2010 8:21 AM
Tony F
October 25th, 2008 5:37 PM
bradstump
September 21st, 2006 10:42 PM
Quick Reply: How can I bypass factory amp
