how to change diff. oil on 08 Suburban?
Can anyone tell me or point me in the right dirrection as to how I can change the diff. oil on my 08 Suburban. Also, would you recommend I use something like Royal Purple if I do some towing?
if your changing the rear diff oil. its simple nothing complicated.
unbolt the diff cover
let oil drain out. get a can of "the right stuff" its a silicone gasket maker in like a squeeze cheese can type.
put that on your diff cover
replace the diff cap to the diff
bolt it back on tighten the bolts with a ratchet hand tight then an 1/8th turn more.
wipe all the excess right stuff off.
there should be a bolt on the right side behind the diff by the driveshaft and should take a 3/8 drive to take it out. fill it til fluid starts coming out.put the bolt back on. drive it for a few days check it and refill if needed.
im using royal purple and havent had any problems with it. i would recommend it. any questions just ask
I am new to these trucks, at what mileage should this be replaced and are their any benefits to using anything other than GM fluid? we just got a 2007 Tahoe that has 46k miles. It looks to have never been used for towing and we probably wont tow much of anything either. Just a gas hog family hauler!
thanks
thanks
digdug
February 4th, 2007 3:08 PM
