How to determine if rear-end is Posi?
Old October 19th, 2008, 1:38 PM
CMOS's Avatar
Default How to determine if rear-end is Posi?
Hey Guys,
I'm about to go help the sis buy a used Tahoe/Yukon (2004-2006). She'll be doing some trailering with her horse so I want to be sure the truck has a Posi rear end.
How do I determine if it does have Posi, and how can I determine the rear-end gear ratio?
Thanks,
Old October 19th, 2008, 3:02 PM
Default RE: How to determine if rear-end is Posi?
check the RPO or build codes in the glove box for one of these:
G80 9027 P AXLE POSITRACTION LIMITED SLIP
G81 9028 P AXLE POSITRACTION FULL LOCKING DIFFERENTIAL, ELECTRONIC, DRIVER SELECT
EDIT
and if you want to know what every one of those build codes means...
http://aplsweb.com/Topics/TopicPix/RPO.pdf
second EDIT the rear end ratios
GU2 8525 P RAX M AXLE REAR 2.73 RATIO
GU4 8527 P RAX M AXLE REAR 3.08 RATIO
GU5 8528 P RAX M AXLE REAR 3.23 RATIO
GU6 8529 P RAX M AXLE REAR 3.42 RATIO
GU7 8530 P RAX M AXLE REAR 2.77 RATIO
GU8 8531 P RAX M AXLE REAR 3.90 RATIO
GU9 8532 P FAX M AXLE FRONT 3.91 RATIO
Old October 19th, 2008, 3:37 PM
CMOS's Avatar
in2,
Do they make the Tahoe/Yukon in an open rear end? If so, what is the build code for the open rear-end? I noticed that the two options you listed above are both Posi rear-ends.
Thanks,
CMOS
Old October 19th, 2008, 3:50 PM
I can't answer the open diff question maybe one of the other guru's Shawnvw or Shark can...
as for the 2 listed one is electroniclly controlled I would assume a part of the driver selected traction control or "StbiliTrak" and the other is the GM standard locker...
If I were to guess the G80 is probably the open
Old October 19th, 2008, 10:23 PM
My 2007 RPO sheet lists the G80 as Differential, heavy-duty locking rear. No G81 is listed.
Jacob Davenport (March 31st, 2024)
Old October 20th, 2008, 1:27 PM
MalibuMaxxSS's Avatar
The G81 I dont know, The only thing GM has with a selectable locker or electric locker is hummer. the G80 is what you looking for, although for pulling a trailor is not a huge helper, its helps more when taking off, in a boat lauch or mud or off camber stuff. It basically lokcs your rear whe none side starts slipping, kinda making it a posi for a bit.
Open diff is what Ford and Dodge and Jeep and those guys run, or 'limited slip' diffs.
The G80 is NOT open. It is when not being used, BUT soon as wheel spin is there it locks both tires, the others (ford nd Dodge)DO NOT. they use cluth packs...
If you want an open diff just get one with no G80 code.....
Old October 24th, 2008, 3:41 PM
CMOS's Avatar
Thanks guys,
The G80 functionality is what I want.
CMOS
Old October 27th, 2008, 10:07 PM
RonH's Avatar
Watch this video to see how the Eaton G80 handles slippage better than anything else
http://www.youtube.com/watch?v=p8nAbg5suFw
Old October 28th, 2008, 5:45 PM
CMOS's Avatar
ORIGINAL: RonH
I've looked at the Eaton web site before when I bought a Tru-Trac for one of my Fords. I never did see anything labeled as a G80. Is this a designation ONLY for GM? Meaning could someone buy a "G80" carrier for a Ford, etc.?
CMOS
Old October 31st, 2008, 4:52 PM
SabrToothSqrl's Avatar
take it off road! if it gets stuck with one spinning in the front, and one spinning in the back, its an open diff; just make sure you have a Jeep handy to pull you out
Go somewhere like here:
http://www.facebook.com/photo.php?pi...50&l=2b598
lol
http://www.facebook.com/album.php?ai...;id=1019051350
Quick Reply: How to determine if rear-end is Posi?
