Last edit by: IB Advertising
- Chevrolet Silverado GMT800, GMT900, and K2XX How to Install a Navigation System
How to install OEM Nav on 2007 Tahoe
#691
Add ons for the Flyaduio unit
For my 2013 Tahoe:
This adaptor can be purchased from Amazon for $2, which will allow you to connect your factory USB cable to the Flyaudio USB connection, to use the console USB media connection.
This $20 32GB micro USB drive will plug into your console connection and you will not even notice it there. Now you can run all your music from the Flyaudio DVD/USB function.
#693
"i have a 2007 chevy tahoe with a bose system and im trying to install a
gm 25966513 dvd navigation radio, the problem that im having is that when i plug everything in, the display does not turn on, but there is a fan inside that is always running. Ple..."
#694
kind of a different question but i just installed Rosen screens in my 07 Tahoe and im having trouble finding where to wire the power/ground wires. Anybody out there do this install before? Any help is greatly appreciated.
Are there any pics of which wires to tap into?
#695
2009 Bluetooth Question
I just purchased a 2009 Tahoe LT2 with bluetooth. I have also ordered an unlocked Nav unit from a 2007 Tahoe that I plan to install. I have read on here that only the 2009 nav units are compatible with bluetooth. However, other posters have indicated that their bluetooth worked with 2007 units and that the bluetooth is not a part of the nav unit.
What bluetooth features will I not have access to using a 2007 nav unit in a 2009 bluetooth enabled Tahoe?
#696
You should be all set. I don't think you'll have any feature limitations. Just make sure you connect the VSS wire when you install the Nav unit.
#697
My DVD/CD Deck is starting to get Optical Errors. I have a 2008 Suburban, and I'm looking at the following deck:
Eonon M1 with Miracast| Car GPS | Car DVD GPS | 2 Din Car GPS DVD | In Car DVD | Best Car GPS
It has a DVD player and support for multimedia connectivity to Smartphones using DLNA, Miracast, USB inputs, etc.
DLNA lets you share media from your phone(MP3, movies, pics) and Miracast is direct reflection of your screen, so you can play Netflix, Youtube, and Google Maps right off the phone. It has plenty of outputs for the rear monitor.
My only concern are turn signal noises and hooking up to the existing speaker system.
Anybody have aftermarket stereos in their burbs?
#698
One good stuff to maintain all the functions and functionality of your sound system when installing an aftermarket sound is to install a replacement interface. Here is the link of the interface I have installed in my 2003 Suburban: Pac-Audio.com Product Details | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
#699
I'd like to add that you will need to erase the vin out of new radio " unlock" to do this you will need tech 2 or launch idiag Scantool (which is on eBay for 60 bucks or so plus 66$ Chevy software purchase)
Instructions
Tech 2: (note this will not work with tech2win)
Log in as 06 Monte Carlo Ltz body code w
( I know your truck is Tahoe or suburban just bear with me)
Select entertainment and then radio
Select setup module
Select learn vin
Shut key off for 30 seconds and try it should be unlocked
Launch instructions:
Log in to your vehicle launch has feature for your vehicle .
Select radio
Select setup module
Select learn vin
Shut key off for 30 seconds then try it
Hope this helps , the fact to remember is it blanks out vin and when you cycle the key it will learn the new vin
Instructions
Select setup module
Select learn vin
Select radio
Select setup module
Select learn vin
#700
We installed an OEM navigation from a Chevy truck into our Suburban. Everything is working fine except the when using NAVI it is not redirecting if we make a wrong turn OR speaking to us for the turn by turns. It does however say " please proceed to the highlighted route" but that is the last thing it says. Any insight as to what we have missed? We took it back to the Chevrolet who unlocked the radio for us and programmed it to our suburban and he had no idea.
rahb0sse
Silverado & Fullsize Pick-ups
May 2nd, 2011 12:06 AM
