how many quarts? - Chevrolet Forum - Chevy Enthusiasts Forums
how many quarts?
tedjackson7's Avatar
June 19th, 2010, 11:42 AM   #1
how many quarts?
I recently bought a '98 5.7 litre suburban. Ive seen many posts that have said this motor takes 5 quarts. I changed the oil today and put in 5 quarts. It measured about an inch high on the dip stick. I drained about a quart and the level is fine now according to the dip stick.
Does this sound correct? 4 quarts?
If this isnt right I am wondering if maybe I dont have a dip stick that is the correct length.
gotstylez's Avatar
ohio
June 19th, 2010, 12:59 PM   #2
look in the manual..it will tell u everything
June 19th, 2010, 1:22 PM   #3
the manual also says 5 quarts....i dont mind running it a quart low but i would like to know why 5 quarts is so high on the dip stick
maxxman04's Avatar
kentucky
June 19th, 2010, 1:33 PM   #4
did you change the filter too, or just oil?
KC, MO area
June 19th, 2010, 2:00 PM   #5
Could be that someone replaced the dipstick w/ the wrong one. Could be that there's a quart of sludge in the bottom of the pan.
LARIDERS's Avatar
Michigan
June 19th, 2010, 2:07 PM   #6
on my 99 5.7L I always used 5 quarts with a oil change and filter.
June 19th, 2010, 5:33 PM   #7
yes, the filter was changed also
sludge could be the case, from now on i will make sure the motor is fully warmed up before changing
Tags
Sponsors
