Suburban won't start after disconnecting the battery
We don't drive our Suburban in the winter so we had the battery out of it. We put it back in and it rolls over but won't start. Sometimes backfires through the carb. Seems like it needs reset. Does anyone know how to do this?
It's a 1999 so yes it does sound like a timing issue but you can't adjust it like the older engines before computers. It ran fine when we parked it which is why we were thinking the computer just needs to be reset.
my 95 does the same thing, each and every time the battery is disconnected. The only way for me to restart is turn the key to "on", put gas pedal to floor then start. Takes a couple seconds but usually fires right up.
Thanks for the info. We did find the pedal to the floor in the manual and had tried that. But it was after several attempts otherwise. We also tried the leaving the key in the on position idea that some had posted about the security system reset. Tried again several times last night. Tried again this morning and it fired right up. Now it starts fine. So for others - I think holding the pedal to the floor as a first try is your best bet. Thanks for the help!
badgunz
January 24th, 2016 5:26 PM
sheridan1952
Express & G-Series Vans
October 3rd, 2014 7:59 AM
KDaniel
Silverado & Fullsize Pick-ups
November 26th, 2013 4:35 PM
