Issue with heated seat - pleas help!
Old September 28th, 2012, 12:55 PM
CarolinaJ's Avatar
Default Issue with heated seat - pleas help!
I have a 2003 LT Suburban, all of a sudden as soon as you turn the truck on the driver side heated seat turns on by itself, then it goes from high to medium to low and then stars all over again, all on its own!!! What the heck?!! If we turn it off manually it stays off for like a few minutes and then starts again.
Old October 8th, 2012, 9:41 AM
Sud
Sud's Avatar
Having the exact same problem on a 04 Suburban. Just started to day...I'll let you know what I find out.
Old October 9th, 2012, 9:42 AM
CarolinaJ's Avatar
Actually ours stopped doing it after two days. Our guess is that hubby left the window open while it was raining and some how water got to it.
Old October 11th, 2012, 4:16 PM
Did you check the fuse?
Old October 13th, 2012, 3:13 PM
staggerlee's Avatar
Curious as to what the fuse would have to do with it?
Its just a fuse, its good or bad thats all.
Thanks,
Lee
Old October 14th, 2012, 4:05 PM
P Kent Gravely's Avatar
Yeah, it would be a relay, not a fuse. The symptoms you describe sounds like the computer controlling a timer is confused. Mine has recently started to not heat the seat, just the back, If I turn the back on, its works great, if I turn the bottom and back, it clicks off after about 30 seconds.
Rbahri5206
February 14th, 2015 3:02 PM
2004TahoeZ71
April 1st, 2009 1:49 PM
Sergio_t1
Avalanche
March 17th, 2008 6:57 PM
slt780
August 6th, 2007 10:42 AM
Mark_MS
Silverado & Fullsize Pick-ups
February 12th, 2007 2:24 PM
Quick Reply: Issue with heated seat - pleas help!
