Freon
Old August 23rd, 2008, 9:27 AM
Elmer Fudd's Avatar
Default Freon
1996 Tahoe 4x4, 5.7 v8. Where do you add freon? I read where it was the larger of the two lines off of the evaporator. I thought the evaporator was under the dash? Would this bethe same larger line on the compressor? Hope someone can answer this, as it is still hot down here in Texas. Thanks
Old August 23rd, 2008, 4:11 PM
Default RE: Freon
You should have the system checked out by a professional
You add the freon under the hood at the low side. The high side is the warmer or hot line the low side is the cold or cooler line.
Its added thru the Schrader valve near the front of the engine near the AC compressor.
There are 2 lines the high side and low side both have the Schrader valves,
If you add it to the high side you risk over pressurizing the Freon can and it exploding taking out a hand or two and an eye or two.
prior to just adding Freon, as just adding it will not fix anything for long, that and just adding the Freon without the proper lubricants can destroy the compressor and its components.
You will also need to verify if you need the R134a or R12 I think 1993 or 94 was the transitional year for the 2 cfc's but I won't swear to it. You also need to know if you need to add the Freon as a gas or a liquid, can upside down or right side up. You should have the system checked out by a professional
EDIT
here are some good sources of info
http://www.familycar.com/classroom/ac1.htm
http://www.aircondition.com/
another good link for doing it yourself, take note of the warnings and cations....
http://www.instructables.com/id/Addi..._Condtioning_/
Old August 24th, 2008, 11:38 PM
Banned
shawnvw's Avatar
Default RE: Freon
I HIGHLY suggest that you take the truck in if you can't spot the a\c ports under the hood. You can seriosuly harm yourself trying to mess with your a\c
Old August 27th, 2008, 9:37 PM
Default RE: Freon
Besides hurting yourself, you can also screw up the system if you do it wrong.
Phillips211
June 12th, 2015 11:15 AM
BAUSTIN
August 2nd, 2011 11:45 PM
VCDRNY
July 16th, 2011 2:41 PM
jarrewdrett
August 5th, 2009 7:38 AM
#1DEER1I
July 28th, 2009 8:44 PM
Quick Reply: Freon
