Notices
Knocking in sterring/front end
Old January 4th, 2009, 4:30 PM
darrowl's Avatar
Default Knocking in sterring/front end
I have a 2004 Tahoe, I am getting a knocking in the sterring/front end while turning. I knowthere was a service bulliten when it was under warranty, but I can not remeber what they did to correct it. I think it may have been something in the sterring intermidiate shaft??? And had something to do withre-packing it with grease. I am pretty handy with working on this kind of stuff, but need a little help on this one. Can anyone tell me were it is located in the sterring system and what the steps might be to correct the problem.
Thanks!
Old January 4th, 2009, 6:23 PM
Default RE: Knocking in sterring/front end
Welcome to the Tahoe forum. I just had my wife's 2004 Tahoe that had the problem w/ the intermediate coupler. Since it was out of warranty, I figured it would cost me $100 to $200 but since GM had come up w/ a new design, they did it for free. Said it was customer appreciation. I didn't buy the truck there although I did buy my '07 there. Don't know if you can get the same deal or not.
Old January 4th, 2009, 9:52 PM
Professional Mechanic
MDTAHOE's Avatar
Do you feel it in the steering column? If so most likely it is the steering shaft. You need to have a steering and suspension evaluation, if everthing is tight it is the shaft (prove all else is good). I see this quite often on GM cars and trucks. The service procedure for the tahoe has been changed from lube the shaft to replacing it. There are actually 2 shafts when I called for parts on the last one we did at my shop the parts guy told me there is a bulletin for knocking on both shafts. He said they replace both of them,
kevin05
July 26th, 2012 11:26 AM
rayzer
Silverado & Fullsize Pick-ups
November 12th, 2009 7:13 AM
dcsweet
September 4th, 2009 7:06 PM
tableclocks
October 13th, 2007 11:15 PM
Quick Reply: Knocking in sterring/front end
