Locked up wheel bearing hub assembly on 1997 Suburban K2500
Hi all, I have an issue that is causing me some grief. I replaced my wheel bearing hub assembly on my 1997 Suburban K2500 (8 lugs) and the axle shaft does not spin after tightening the bearing hub assembly bolts to the knuckle using 133 ft/lb torque. If I loosen the bolts it spins. Can anyone offer some insight into this? Thanks so much.
Stevoray81
October 30th, 2014 10:30 PM
jrsavoie
April 15th, 2010 10:58 AM
