need help with a 94 suburban
Okay, so the story goes, and shoild start off with if it ain't broke..dont fix it.
Was replacing dizzy because the pickup coil was cracked, still ran fine, but was cracked all to hell. So I replaced it, now my truck wont run for the life of it. I'll start up like a million dollar truck, but wont stay there. It boggs, the motor shakes, and just hates life. Im 100 percent positive its on #1 tdc, ive checked it based on valves, harmonic ballencer, and the piston its self. It wont rev with the ignition advance wire plugged in, the wire underneath the dash to set the timing(you have to unplug it to set the timing on a 350 tbi) anyways, ive tried advancing it, retarding it, leaving it at 0, almost every way it will rev fine with the wire unplugged. Plug it in and its the same old story. If I leave it unplugged and drive it down the road it pings(no advance at all) so I cant leave it. I need help. The timing is correct. What else could that little wire be controlling? I dont have a crank sensor, so that's not it. Im confused.
Truck is a 1994 chevy k2500 suburban
350 tbi
4l80e trans
Everything was fine until it does one day, fixed what killed it(overheating icm) and went ahead and replaced whole dizzy. It ran fine with the new icm, replaced dizzy and it does this.
350 tbi
4l80e trans
350 tbi
4l80e trans
350 tbi
4l80e trans
NateP1134
Engine Building & Overhauling
September 24th, 2015 12:05 AM
be_Martinezr
October 6th, 2014 10:19 AM
1stTahoe
April 19th, 2012 9:44 PM
upzaw2000
HHR
December 31st, 2006 9:36 PM
