OEM wire colors
Old August 4th, 2007, 10:11 PM
goldie8919's Avatar
Default OEM wire colors
Does anyone know how I could get a hold of the OEM wire colors for a 1997 Tahoe. Im trying to get my alarm installed.
Old August 5th, 2007, 1:01 AM
copout221's Avatar
Default RE: OEM wire colors
12volts
red
ignition harness
Starter
yellow or purple
ignition harness
Ignition
pink
ignition harness
Power Lock
lt. blue
either door boot
Power Unlock
white
either door boot
Lock Motor
gray
drivers door boot
Unlock Motor
tan
drivers door boot
Disarm Defeat
tan
passengers door boot
Parking Lights+
brown
headlight switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger
purple
headlight switch
Dome Supervision
white
headlight switch
Trunk/Hatch Pin
tied in with doors
Hood Pin
Trunk/Hatch Release
black or blk/wht
low in the drivers kick
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer
white
AC
ECM
Horn Trigger
black
at column
Memory Seat 1
Memory Seat 2
Memory Seat 3
CHEVROLET, TAHOE, 1997, Power Lock
The 4 door versions are positive trigger, and the 2 door versions are 5-wire.
CHEVROLET, TAHOE, 1997, Trunk/Hatch Release
Positive trigger on models with rear lift window, and 5 wire on models with cargo doors.
CHEVROLET, TAHOE, 1997, Tachometer
Diesel wait to start wire is dk. blue (-) located at the instrument cluster.
ECM is located on drivers side inner fender. Tach wire found in a black plug marked white
Old August 5th, 2007, 9:43 AM
goldie8919's Avatar
Hey thanks for the feedback. For the links that were provided, is there some type of password that i need for the directechs.com site? like theres a couple of links on the reply that have no info, its just a link... is there impt information needed in those links? thanks.
Rescue30
October 14th, 2020 9:08 PM
RacerX
September 19th, 2011 9:59 PM
SINNER
K5 Blazer
May 25th, 2010 11:33 AM
steiner
November 4th, 2008 6:21 PM
93cav4c
August 22nd, 2006 8:15 AM
Quick Reply: OEM wire colors
