oil filter
#11
If the vehicle has been sitting and cold, you should only loose the equivalent of what is in the filter 1/2 to 1 quart at most... there may be some run out from the pump plumbing that gets siphoned out.
#14
Yea I would say both are prob not the cause as I knew the last one was wet as well so I made sure I cleaned the area real good. I put on filter like I normally do. Im gonna put on a mobile 1 filter and hope solves my issue. If it leaks again not sure what the next step is.
DeHartShadow
October 22nd, 2013 10:52 AM
