P0442
Old October 5th, 2011, 5:32 PM
Default P0442
I had my first check engine light today my 07 Tahoe with 61k miles, it was a P0442... I cleared it for now to see if it resets but read up on it and found this info below... found it interesting about the module on for up to 40 minutes and to keep in mind when addressing parasitic draw test...
Evaporative Emission Control System Description
Small Leak Test
The engine off natural vacuum (EONV) diagnostic is the small-leak detection diagnostic for the evaporative emission (EVAP) system. While previous leak detection methods were performed with the engine running, the EONV diagnostic monitors the EVAP system pressure or vacuum with the ignition OFF. Because of this, it may be normal for the control module to remain active for up to 40 minutes after the ignition is turned OFF. This is important to remember when performing a parasitic draw test on vehicles equipped with EONV.
The EONV utilizes the temperature changes in the fuel tank immediately following a drive cycle to use the naturally occurring vacuum or pressure in the fuel tank. When the vehicle is driven, the temperature rises in the tank. After the vehicle is parked, the temperature in the tank continues to rise for a period of time, then starts to drop. The EONV diagnostic relies on this temperature change and the corresponding pressure change in a sealed system, to determine if an EVAP system leak is present.
The EONV diagnostic is designed to detect leaks as small as 0.51 mm (0.020 in). The diagnostic can determine if a small leak is present based on vacuum or pressure readings in the EVAP system. When the system is sealed, a finite amount of pressure or vacuum will be observed. When a 0.51 mm (0.020 in) leak is present, often little or no pressure or vacuum is observed. If the test reports a failing value, DTC P0442 will set.
SRL S10
October 26th, 2013 4:39 PM
greglane1977
Silverado & Fullsize Pick-ups
November 13th, 2012 5:38 PM
camotruck55
December 15th, 2011 1:53 AM
EddieClassic07
December 11th, 2011 1:53 PM
digarta
January 22nd, 2009 9:59 PM
Quick Reply: P0442
