Power Window problem Tahoe -00
My rear left power window is suddenly out of order (the window is closed at this moment). When i push the power window button to open the window i can hear a "click" noise but nothing happens. If i push the button to close the window i have the same "click" noise as on the other doors when i push theirs button to close position when they are already closed.
The fuses seems ok and the power lock and the door light works ok.
Could it be the power window motor or some other fuse/fuses that i don't know about?
Best regards
Christer
Best regards
Christer
RE: Power Window problem Tahoe -00
Had the same problems on my '01. The rear plug in came loose(how, I have no idea) and on the front motor, lost the ground someway.
ORIGINAL: sjenkinzz
The "clicking" comes from the control button not from the motor, (and have the same sound on the other doors when i try to close a closed window).
I have power to the door as the powerlock and light works. I have loosen the wiring contact from the body and put on some contactspray and put it back but without any change.
There is a square bulb on the wiring rubber, could it be a fuse there?
I have the same problem on 04 tahoe, after I installed a in-dash dvd player, i'm not sure if i blew a fuse or what, but neither the driver nor the passenger door have any power to the windows or locks, but the rear doors, the windows function on. I don't understand what the deal is? if anyone knows what may be the problem, can you please give me a solution, a.s.a.p oh and also in the gauge cluster nothing works but the speedometer and the rpm meter, all the others are all the way to the left, like says i have no gas... and some lights are on, like ABS .. Battery light... etc If anyone knows how i can fix this please let me now..Thanks =)
¤ Jonathan ¤
¤ Jonathan ¤
ORIGINAL: guitarplayer
Best regards
Christer
Best regards
Christer
davbell22602
Silverado & Fullsize Pick-ups
March 10th, 2010 8:36 PM
