convert '97 burb 2x4 to rear disc brakes
I have a 1997 GMC suburban c1500 2x4 with a drum brake in the rpo is GU6 -- AXLE REAR, 3.42 RATIO
will a rear axle from s10 zr2 with disc brakes work?
or another rear axle 3.42 ratio with disc brakes and 5 lug wheels?
drum brakes suck (the self-adjuster doesn't work)
any suggestions would be great maybe a (g body van, Camaro, or impala?
or conversion kit & keep the same rear axle
thank you
kiddbrother
thank you
kiddbrother
thank you
kiddbrother
thank you
kiddbrother
More bother and expensive to convert than fix it right. Your talking master cylinder, proportioning valves and possible ABS unit.
Parts stores carry rear brake hardware kits cheap. Those kits come with new springs and adjusters and will restore normal operation.
Whenever I service drum brakes, I put new hardware kits in.
oilcanhenry (January 27th, 2023)
G3500 Toy Hauler
Express & G-Series Vans
November 1st, 2022 6:02 PM
