Rear window defogger leads
Old December 3rd, 2012, 3:33 PM
BMoTahoe's Avatar
Default Rear window defogger leads
Has anybody else had a problem with the defogger leads popping off the window? If so, what did you do to repair it? This is the 4th time I''ve gone through this and it's getting a little frustrating. I went to Bob Bell Chevy here in Baltimore and they told me it can't be soldered and they'd have to replace the glass, AT A COST OF $932.00. Problem is, the cables are wound too tight and they're too short but GM doesn't want to own up to it.
Old December 3rd, 2012, 8:05 PM
You can stretch the cables so they don't put any tension on the terminals when the glass is closed.
Some have had success using conductive epoxy in place of solder.
Old December 4th, 2012, 6:01 AM
delta579's Avatar
The existing solder bubble on the glass where the wire is connected can be soldered, I have done two on 2 different vehicles. First the solder is coated with a glue-like insulator, clean/sand this lightly to remove it, then you can solder the wire back. Using a conductive epoxy, like defroster grid repair, will also work. It sounds like you need to extend the defroster wires too. Just use the same size/gauge wire as what's there now. Braided wire flexs better, but primary lead will work too. Hope this helps.
BMoTahoe
April 14th, 2013 9:30 PM
wile13
February 12th, 2012 8:28 PM
merlinroad
November 6th, 2008 6:48 PM
drockwell
September 29th, 2008 5:29 PM
Quick Reply: Rear window defogger leads
