Notices
Rear wiper arm and hose replacement
Old February 4th, 2009, 3:44 PM
samp215's Avatar
Default Rear wiper arm and hose replacement
I need to replace the rear wiper arm and hose on my 2007 Chevy Tahoe. The motor and base is still there, but I need the arm that holds the actual wiper and the hose.
Does anyone know where I can get that? I tried looking in the parts catalog, but all I could find was stuff for the front windshield.
New poster here...thanks for your help!!
Sam
Old February 4th, 2009, 9:08 PM
GM parts direct has the parts you are looking for...
can or should I ask why you need those parts?
Old February 4th, 2009, 10:59 PM
samp215's Avatar
Default Liftgate!!
I never looked there....thanks man!!
As for why I need to replace....lets just say Wild Turkey didn't treat me too well that night.
Old February 5th, 2009, 7:25 AM
lol yep Wild Turkey can do that....
Old February 5th, 2009, 1:33 PM
And I was just going to say the garage door gobbled it up. Turkey is good stuff.
Old February 5th, 2009, 1:52 PM
Thats funny Marc because I though the exact same thing about it being the garage door taking a bite of the Tahoe.... that is what led to me having to ask...
I used to use the ole tennis ball hanging from the ceiling in the garage to know I was in far enough, but upgraded to the "laser" parking system when I got the 07 Tahoe.
Old April 17th, 2009, 4:25 PM
zonian87's Avatar
Default rear wiper arm for 2007 Chev Suburban
I have been searching online trying to find a rear wiper arm for a Chevy Suburban 2007 and I came across this forum with info for a Tahoe. Would the parts for the rear wiper assembly for the Tahoe work for a Suburban?
Mine suffered children with no fear... they used the arm as a "leg" up to the roof of my Suburban.
Thank you for your time.
Kelly
Old April 17th, 2009, 6:43 PM
Welcome to the forum,
I don't see why it wouldn't but check partstaxi.com or the GMpartsdirect.com to double check.
if you do change it take before during and after pictures if possible and post, makes it just a little bit easier for the next time
Old June 20th, 2011, 11:16 AM
cgmoran's Avatar
Default How to remove 2007 Subirban rear wiper arm?
I am trying to replace my broken 2007 Suburban rear wiper arm. I removed the nut; however, I am not able to remove the arm. Is there a catch or something that needs to be released for the arm to come off?
Thanks,
Chris
Old June 20th, 2011, 1:46 PM
Try spraying some Kroil or other penetrant on the shaft after you remove the nut. I suspect that the shaft is splined. Might even take a small gear puller and remove it w/ that.
ruley73
Equinox
21
September 15th, 2017 8:11 AM
Silv1441
May 8th, 2014 4:33 PM
Chevyaz
Silverado & Fullsize Pick-ups
March 14th, 2013 10:58 AM
DaveO
November 3rd, 2011 7:35 PM
mdjbhouse
April 23rd, 2010 6:28 PM
Quick Reply: Rear wiper arm and hose replacement
