Notices
AC Heater not functioning properly
Old June 12th, 2011, 11:34 AM
viper_gts_dude's Avatar
Default AC Heater not functioning properly
I have a 2004 Suburban with an AC/Heating control problem. The passenger side does not follow the command from the dash controller. No matter how you set the passenger temperature levels, it does not cause the blower motor to respond. Additionally, the directional flow control does not cause the diverter doors to exhaust the air from the correct vents (defrost, dash, floor). The drivers side is able to have AC at the vents, but not FULL cold. (I know the system is charged as the rear air blows full cold. Rear system works perfectly). So, it seems that there are at least two problems, where the blower motor command on the right side does not cause the motor speed to respond to a change in temperature command nor to divert properly, and the driver side does not cause the blending do to react.
I have looked at the circuitry internal to the dash control assembly, and nothing looks burnt or damaged. The display operates perfectly and responds to every user command; the balance of the AC/Heating system does not.
Is there another control assembly elsewhere that directs the diverter/blending doors?
Thank you for your help!
(Please don't ask me to take this to a dealer or mechanic. I am an experienced mechanic just not with this model.)
geddiesburg3d
September 10th, 2022 8:14 PM
ctbimmer
March 8th, 2020 6:04 PM
Normanator
Equinox
March 17th, 2015 10:18 PM
iceypath
May 7th, 2012 3:45 AM
AAN
January 18th, 2007 6:43 PM
Quick Reply: AC Heater not functioning properly
