Remote door lock stops working
I have a 2007 Chevy Tahoe purchased just about 8 months ago. When I bought it the remote worked fine. About 3 months later it stopped working. Now it only works if I unlock the driver door with the key first it will work. It will also work right after u turn it off and get off, I am able to lock the doors with the remote. Wait about 2 minutes after that and it wont work anymore. I got some programming instructions for the remote from a local locksmith but still didn't fix. Any suggestions on what the problem might be?
The remote could be going bad. Put a new battery in the remote and try it again. If that doesn't work then you probably will have to replace the remote.
I have already tried the new batteries at the local locksmith but still same issue. When I bought the Tahoe it came with 2 remotes and same issue on both. I don't think its a problem with the remotes
May be RCDLR problem
Look at the 4th item in this old thread.
https://chevroletforum.com/forum/tah...list-07s-4039/
cnterline
Silverado & Fullsize Pick-ups
40
December 9th, 2021 11:48 AM
wad5520
December 2nd, 2011 10:51 AM
