Remote start not working correctly
#11
RE: Remote start not working correctly
Try hitting the unlock the required two times a little slower and delay each step so that you finally hit and hold the start button a longer time after you first start the sequence. Remember the fuel pump needs to be activated. I'm assuming that the first unlock in the sequence gets several systems turned on and you may be trying to fire it before the fuel is available. I know unlocking and opening the door activates several systems and maybe that's why it starts with the key.
Get it looked into but try this in the mean time.
#12
My manual says to press the remote lock and then press and hold the remote start until lites flash or more than 4 seconds if you can't see truck. Also says will run for ten minutes on first start and can be extended for ten minutes after which it must be started with the key.
#13
ORIGINAL: ScootersLTZ
New '07 Hoe and my remote start will not always work. It is an intermittant problem that seems to be related to how cold it is outside. When I try to remote start it, it fires up and dies. Once it does that, you cannot get it to try again. Took it to the dealer and they say there are no error codes and they could not get it to do the same thing. When it is 20 degrees or less I notice it does not start about 1/2 the time. Kind of makes the remote start useless!
Anyone else having this problem, or know how I can correct it?
This morning my truck wouldn't even remote start at all. The lights would register, I'd get in the truck, and all indicators would lead to believe that it was running, but it wasn't. Then I'd hit the center key on the remote to turn it off, and all of the electronics would power down as if the car shut itself off.
I'll keep everyone posted on what I find out. You all please do the same.
[IMG]local://upfiles/5036/5F1E0079B4CB4803BB28D66C1F16A38E.jpg[/IMG]
#14
The RVS system will not operate if any of the following conditions are present: [align=left] • The vehicle is in valet mode.[/align] [align=left] • More than 2 remote starts have been attempted.[/align] [align=left] • The hazard switch is in the ON position.[/align] [align=left] • A current hazard switch DTC is set.[/align] [align=left] • The vehicle hood is ajar.[/align] [align=left] • A current hood ajar DTC is set.[/align] [align=left] • The CTD system detects an alarm trigger.[/align] [align=left] • Excessive engine RPM[/align] [align=left] • Excessive coolant temperature[/align] [align=left] • Accelerator pedal position greater than 0 percent[/align] [align=left] • Vehicle not in park[/align] [align=left] • Vehicle theft deterrent malfunction[/align] [align=left] • A current automatic transmission shift lock control system DRC is set.[/align] [align=left] • A vehicle speed sensor signal is detected by the ECM.[/align] [align=left] • A current vehicle DTC that illuminates the malfunction indicator lamp (MIL)[/align]
#15
Thanks for that as always!!! Man there sure a lot of variables there huh. A lot of things can be faulty or "buggy" to stop the remote start from functioning. Makes it difficult to troubleshoot.
Dumb question now: We have a valet mode? If so how does it work?
#16
I did a quick copy and paste and didn't take much time to proof read this.
No "valet mode" on the Tahoe, we're trying to find the dummy that wrote that so we can take a toilet brush to his behind.
It should read:
• Remote start feature is disabled in the DIC
It should read:
#17
So ZX1100F1,
Any thoughts on what might be goin' on with everyone's remote start, based on what you've read so far? I ask because mine did it yet again this morning.
#18
Well, we're out in cold Idaho for the holidays so I have been playing with it quite a bit. Seems the trick is that you have to unlock it (to get the brain working) and not just lock it and start. Mine sits in the garage unlocked, and when I lock it and try to start it, it fails more than half the time. If you unlock, lock and then start, it has worked every time. Guess it's just another wierd quirk they built in...
