Notices
Replaced crank sensor - got P0430 CEL
Old August 19th, 2010, 2:21 AM
TCsix's Avatar
Default Replaced crank sensor - got P0430 CEL
I replaced my crankshaft position sensor and drove about 200 miles before the CEL came on - P0430. Is there any adjustment / tune-up that needs to be completed after the CPS was replaced? My Suburban is running a little rough. Factory shop wants to replace all four O2 sensors and CAT for ...$1,400.
Old August 19th, 2010, 9:12 PM
Professional Mechanic
MDTAHOE's Avatar
po430 is catalyst efficiency below threshold bank 2. 99.9% it is a bad cat. There is NOTHING that could cause this in relation to the crank sensor. The O2 sensor are not needed, they are what is seeing the problem. Bank 2 is the passenger side. Even if it was a o2 sensor problem it would only need the 2 on that side. Replace the cat it will be fixed. If you use a cheap cat most likely it will be back on in less than 2 years.
slosol93
June 15th, 2015 9:57 PM
travismm
February 25th, 2014 4:09 AM
vinman46
Silverado & Fullsize Pick-ups
January 27th, 2012 6:44 AM
Copedawg
February 2nd, 2011 3:50 AM
3647dan
December 1st, 2009 1:06 AM
Quick Reply: Replaced crank sensor - got P0430 CEL
