Scan Tool for 07 Burb help needed.
Anyone know of a good scan tool? I don't mind spending up to $250. I have been looking... and this one doesn't do this... this one doesn't do that!
It's becoming a real PITA!.
I like the INNOVA 3160? Its about 249 on amazon right now. I had bought it when it was about 190, but returned it since I felt like I didn't need it. lol. It scans airbag fault codes as well.
What do you need it to do?
Good cheap tool is the launch c-readervi for under $100
autoenginuity makes the best laptop based system that does everything. approx. $300 for the gm software.
check out all the scan tools on this site.
http://www.autorepairmanuals.biz/page/924074
So I looked on Amazon. Under the Auto section, you can plug the vehicle you have and it will tell you want will and will not work on your truck.
How come the one I want, Amazon says will not work on my truck?
I'm confused, shouldn't anything that is OBDll capable, work?!
I have the one step up from the cheap basic one for whatever I need for on short notice. If I need to use a better one I go to use the parts store's fancy one. I like theirs, it's a newer bosch
If you have an android phone I use torque. The full version at google play is like $5, but there is a free version. Use also need an obdII adaptor that plugs in and connects to your phone via bluetooth, cost about 15 on ebay.
Will not due airbag stuff and program things. It can read and erase codes with full descriptions. You can set it up to watch realt-ime misfires, abs, fuel injector pulses. Will show vin, miles and other live info like coolant temp, oil pressure rpm,speed, mpg.Works on any obdII. Does alot of cool things
Is anyone going to actually answer my question?!
These last replies didn't touch the subject.
I follow this tread when i need a scantool to initiate the calibration of crankshaft position sensor on my 1996 5,7 Tahoe. Want it to work on my 2003 Suburban too so i can do more than just read and reset faultcodes.
Was offered an GM Tech3 but no software included and as i understod i need an expensive license from GM to work online to a server that holds the software and data i need to the Tech3. Is that right ?
