Notices
Service Park Assist Message
Old May 18th, 2014, 7:32 AM
Habnixzuverliern's Avatar
Default Service Park Assist Message
Hi,
need help finding the problem with my Park Assist Module. I got the message in the dic, and read out the dtc and found out that i have random error messages, so i checked the cable and the cable are fine, so i bought 4 new sensors, no change, so i replaced the alarm module.
So now i am stucked, still have the problem, that i got random error messages, starts with shorting to ground or 12V or i got Bxxxx 08. Does somebody had the same problem? I can not find the problem, because it change depending on the installed combination.
Cheers.
Old November 25th, 2014, 8:49 AM
william stewart's Avatar
iam just seeing if you figured out the problem with your park assist? i changed all sensors wiring harness and module with no luck.
Old November 28th, 2014, 10:57 AM
Yes, i die the same. I found out that the radio is the problem. I had a new radio and this was the problem. After installing the factory unit, the pdc start working.
Cheers
Old January 29th, 2024, 3:18 AM
Alejcruz's Avatar
Cheers
So changing your radio fixed your service park assist error message?
JimmyD55
Silverado & Fullsize Pick-ups
March 20th, 2023 7:54 AM
glevy
October 2nd, 2019 3:33 PM
boydchr
June 25th, 2015 11:25 PM
db7am
February 7th, 2008 9:32 AM
db7am
Paint, Body, & Interior
February 7th, 2008 9:28 AM
Quick Reply: Service Park Assist Message
