Notices
Voltage
Old April 11th, 2009, 4:18 PM
Ecker's Avatar
Default Voltage
Commanded Duty Cycle
10% /20%/30%
Generator Output Voltage11 V/11.56V/12.12V
These values from a Chevy graph leave me confused. My understanding has all ways been that generator charging voltage must be higher than battery in order to force the charge into battery. Why then, to use the 10% commanded duty cycle, is the output voltage only 11 volts?
Old April 15th, 2009, 6:46 PM
Banned
shawnvw's Avatar
If battery voltage is high, and demand for current is low, the computer is programmed to not charge the battery as it has a sufficient charge in it.......saving gas and giving you that extra .5mpg
mystrg
March 26th, 2008 3:19 PM
fyrflie
March 8th, 2007 6:58 PM
schorner
November 1st, 2006 8:42 PM
twfinch
September 26th, 2006 2:38 AM
Jonathan93
August 8th, 2006 4:03 PM
Quick Reply: Voltage
