Traction Control malfunction
2013 Impala traction control was shut off when snow and ice off the roads. However the next day while sitting at stop light and starting off on a green light with sudden acceleration, and turning left, the traction control came on and almost stopped me dead in the intersection. Not good. Potential for an accident big time! It has done it several other times since then today while accelerating from dead stops and turning. I have shut off the traction control again today. I will check to see if its on again tomorrow. It has been suggested that I may have to pull the fuse to keep it from coming on when it is not supposed to be. There is a definite danger of this causing a collision when you are trying to accelerate to get out of an intersection quickly or avoid a possible collision in any situation. I have owned several Impalas and never had this problem before.
Official GM Rep
Our team regrets to hear that you are experiencing this concern with your Impala. Rest assured that customer satisfaction is our priority, and we want you to feel secure in your vehicle.
We’d be glad to check for any open recalls associated with your vehicle that may relate to your concern. Additionally, we can also help connect you with your local certified Chevrolet dealership to have them check out your concerns as well.
At your earliest convenience, please send us a private message with your full contact information, VIN, current mileage, and the Chevrolet dealership you were working with.
To learn more about GM's privacy policy, please visit Privacy Statement | GM.com
Looking forward to working with you!
Best,
Cecil J.
Chevrolet Customer Care
the system will only disable until the car is shut off. the next start up it will be enabled.
the system works fine. there is a reason abs, stability control is mandated by the government on all new cars. your all season tires are probably junk. put a winter tire on you car.
Same BS
Hello PJame,
Best,
Cecil J.
Best,
Cecil J.
according to Expert Mechanucs it a 15 dollar cable to the Hubs that goes bad ? Dealer wants 200 bucks just to Diagnose,? Recall or Not?
Replace cable
Hello PJame,
Best,
Cecil J.
Best,
Cecil J.
Dont waste your money buy the cable for the left side Hub and Done .
Nothing else to replace,just gad it Done at a local mechanic 15 dollar cable from Ebay 75 dollar install.
Replace cables easy fix
No RECALL FROM GM
maybe he should get the codes read first. the op is posting stability control problems with no mention of abs light on. the cost of 4 cables plus the labour to install and t hen to not correct the problem.
Dont
waste of time and money ,Just Buy the cables I did it it worked I saved a ton of money including the 195.00 Dealer diagnostic fee !
