Tranny Question- 4l60e
Quick question and would surely appreciate quick, serious replies. New to the forum so bare with me.
Beginning on the 4th, my auto tranny in my '94 Burban began not wanting to shift from first to second. Once i let it whine out and let off, it will go ahead and shift, then no problems, Only between first and second. I noticed the speedometer going a little squirly a few days ago, but it still works.
While talking to a few people about it, they mentioned it was probably the speed sensor. Any thoughts? The fluid level is fine and the tranny was replaced about a year and a half ago..... please let me know if you need any more info.
Professional Mechanic
The fact that the speedometer is acting funny it is a good possibility that the vss (vehicle speed sensor) is the problem. And until it is tested or replaced it can not be eliminated as the cause.
Mdyahoe is a very smart guy! I saw it I was going to tell you it sounds like VSS but I did'nt know for sure so I waited! I do not like to awnser questions I do not know for sure! But if your VSS does not fix it report back and let us know!
EEEH! Wrong.
Welp..... replaced the VSS and no luck. Reset the computer, and no luck. checked for hurt vacuum lines, Still no luck..... I'm at a loss..... i think i've run out of little things to try.
donbrearley
Silverado & Fullsize Pick-ups
June 26th, 2013 10:26 AM
abqgolfer
August 27th, 2011 11:30 PM
