Fog Light Issue
Fog Light Issue
I just replaced the fog light assembly on my 02 burban. Now when I roll over bumps and pot holes, I can see the light shaking. I couldn't tell if it was shaking before because I had the 27 watt bulbs in. Now I have hid's installed I see the light shaking. I need some ideas to fix this problem. Thanks for your help.
it's probably just the mounting bracket. not necessarily broken, just the way it is. my 04 pickup does the same thing. lightweight plastic mount doesn't take to bumps too well. might be able to fab up some sort of stabilizer, or better, stiffer mounting brackets.
73Shark - Just wanted to say that the Tahoe comes stock with white lights in the fog lamps. White is not for fog, it's for driving. Which is why they are also called driving lights.
SilverWolve
Silverado & Fullsize Pick-ups
November 9th, 2014 1:38 PM
whitesox1933
July 28th, 2012 8:13 PM
larry_chip
June 1st, 2007 6:14 PM
