Updated TSB listings ONLY
Old May 19th, 2013, 2:52 PM
Default Updated TSB listings ONLY
An updated list of TSB's
YOU will need to Google or Bing or what ever your search engine fancy is, the TSB number to track down the relevant information you are looking for, these are ONLY headers for FYI. Please do not post a response/question of what is the info for TSB xxx-xxx Google it!
08-09-41-006E
01/29/2013
08-09-41-006E - BULLETIN CANCELLATION NOTIFICATION
00-03-10-006I
01/28/2013
Tires/Wheels - Information on Tire Radial Force Variation (RFV)
13-08-116-001
01/28/2013
Engine Controls - Aftermarket Interface Devices Cause Issues
08-08-51-002A
01/16/2013
Body - Pre-Painting/Cleaning Process For TPO Plastic Fascias
11-00-90-001A
12/21/2012
Engine - GM dexos 1(R) and dexos 2(R) Oil Specifications/Info.
11-00-90-001A
12/20/2012
Engine - GM Dexos 1(R) And 2(R) Oil Specifications
08-09-41-007I
12/04/2012
Restraints - Passenger Presence System Service Precautions
08-08-46-004A
11/30/2012
Electrical - Aftermarket Devices May Interfere With OnStar(R)
00-00-89-027G
11/28/2012
Interior - Eliminating Unwanted Odors in Vehicles
12-03-10-002
11/26/2012
Wheels/Tires - Proper Wheel Installation/Wheel Torque Technique
10-00-89-010B
11/13/2012
Locks - Key Code Security Rules, Key Code Look Up
12190
11/12/2012
Recall - Fuel Leaks, Fuel Pump Replacement
12-06-01-008A
09/27/2012
Vehicle - Engine And Sub Systems Flushing Info. (CANADA)
04-06-01-029G
09/27/2012
Vehicle - Engine And Sub-Systems Flushing Recommendations
05-03-10-020D
09/18/2012
Wheels/Tires - Use Of Nitrogen Gas In Tires
07-08-49-020G
09/17/2012
Instruments - IPC Odometer Programming Method
00-00-90-002K
09/14/2012
Tires - Information On Proper Tire Pressure
12-03-08-001
08/06/2012
Suspension - Clunk or Thump Noise From Front Suspension
04-06-04-054E
08/06/2012
Engine - THIS BULLETIN HAS BEEN CANCELED
08-07-30-040C
07/25/2012
A/T - Normal Maintenance or Warranty on 4T40, 4T45, 4T65, 4L60
05-06-04-022I
07/19/2012
Fuel System - TOP TIER Detergent Gasoline Information (Canada)
04-06-04-047K
07/19/2012
03-03-10-007G
07/13/2012
Tires/Wheels - OE Tire Shake/Vibration Information
09-08-44-013D
06/26/2012
Audio System - USB/Multimedia Interface Information
12045A
06/06/2012
Campaign - Ignition Lock Cylinder May Bind
05-03-08-002E
05/31/2012
Suspension - Shock Absorber/Strut Fluid Leak Information
03-07-29-004H
05/30/2012
M/T - Operating Characteristics Information
12-05-26-001
05/18/2012
Brakes - Resurfacing Park Brake Portion of Rear Brake Rotor
07-03-10-008C
05/17/2012
Tires - Slight/Mild Edge Feathering Information
00-06-01-026D
05/02/2012
Engine - Intake Manifold Inspection/Replacement
06-08-51-005B
04/30/2012
Body - Hem Flange Sealer For Corrosion Protection
03-00-89-008F
04/24/2012
Body - Metal Body Panel Corrosion Protection
05-00-89-078C
04/19/2012
Fuel System - GM Fuel System Treatment PLUS(R) Info.
04-06-04-051C
04/19/2012
Fuel System - Fuel Injector Maintenance Cleaning
04-08-48-001D
04/17/2012
Body - Broken Rear Window Defogger Grid Detection
08-08-44-028A
04/11/2012
Audio - Inadvertent Steering Wheel Button Activation
06-08-44-015C
03/30/2012
Audio System - Noise When Using Portable Playback Unit
07-02-32-002M
03/27/2012
Steering - Power Steering Leaking Fluid
02-07-30-052H
03/26/2012
A/T - Fluid Oil Cooler Flow Test
12-03-10-001
03/23/2012
Tires/Wheels - Vibration Shortly After Tires Are Mounted on Rim
05-08-46-009C
03/19/2012
OnStar(R) - Language Change Information (U.S. and Canada Only)
12-02-32-002
02/21/2012
Power Steering - Fluid Leaks Due to Extreme Low Temps
02-08-42-001F
02/10/2012
Lighting - Lamp Polycarbonate Lens Damage Prevention
06-08-50-009G
02/03/2012
Restraints - Passenger Presence System Information
06-00-89-029H
01/19/2012
Interior - Cleaning Interior Surfaces of Vehicle
04-03-08-006F
01/18/2012
Suspension - Front Suspension Noise Concerns
09-09-40-001B
01/13/2012
Restraints - Seat Belt Latching Issues/Warning Lights
06-08-64-001C
12/23/2011
Body - Side Window Chipping Information
08-09-41-002G
12/16/2011
Restraints - Air Bag Lamp ON/Multiple DTCs
07-07-30-010C
12/15/2011
A/T Controls - Snapshot Data With Tech2(R) Information
10-08-50-003B
11/10/2011
Restraints - Driver/Passenger Seat Head Rest Information
08-03-10-006D
11/02/2011
Tires/Wheels - Tire Slowly Goes Flat/Warning Light ON
09-01-37-002E
11/01/2011
A/C - Front/Rear Passenger Carpet Wet
00-06-01-012D
10/25/2011
Engine - Use of 'Surface Conditioning Disks'
05-09-40-002F
10/24/2011
Restraint System - Normal Safety Belt Locking Conditions
10-08-44-006A
10/17/2011
Navigation - Report Missing/Inaccurate Nav. Map Info
01-07-30-042G
09/22/2011
A/T - 2-3 Upshift or 3-2 Downshift Clunk Noise
01-08-51-003C
09/21/2011
Body - Application of Anti-Corrosion Materials
99-01-39-004D
08/10/2011
A/C - Musty Odors Emitted From (HVAC) System
07-08-44-001G
06/09/2011
Audio System - Difficult To Install Fixed Radio Antenna
10-08-45-001C
06/06/2011
Electrical - Information For Electrical Ground Repair
08-08-44-023A
05/23/2011
Navigation Radio - Problems After Radio/Battery Service
08-07-30-026A
05/17/2011
A/T - Slight Vehicle Movement In Park At Start Up
10037B
05/13/2011
Campaign - Unwanted Repeat Calls To OnStar(R)
99-04-20-002G
05/06/2011
Drivetrain - Clunk Noise Shifting From PARK Into Gear
00-03-10-002F
04/21/2011
Wheels - Chrome Wheel Staining/Pitting/Corrosion
03-08-48-006H
04/11/2011
A/C - Window Defroster Contact/Tab Repair Information
06-00-89-031B
03/28/2011
Engine, A/T - Identification Information
99-08-51-007E
03/17/2011
Wheels/Tires - Refinishing Aluminum Wheels
99-08-51-001B
03/01/2011
Body - Paint-Less Dent Repair Recommendations
06-08-43-003C
02/21/2011
Glass/Body - Windshield Wiper Performance
09-02-35-005C
02/07/2011
Ignition - Key Difficult To Remove, Binds Or Sticks
06-03-09-005E
02/07/2011
Suspension - Rear End Squawk Noise On Low Speed Bumps
01-08-42-001H
01/05/2011
Lighting - Exterior Lamp Condensation and Replacement
05-08-46-004C
12/23/2010
OnStar(R) - Number Incorrect/Incorrectly Assigned
10256
12/14/2010
Campaign - Ignition Lock Cylinder Binding
05-03-07-009C
12/09/2010
Steering/Suspension - Wheel Alignment Specifications
10-06-04-015
12/08/2010
Fuel - GM's Position On Use Of E 15, 2007 Newer Vehicles
10-06-04-001C
12/08/2010
Engine Controls - MIL ON/DTC's P0451/P0454 Set
09-06-03-004D
12/08/2010
Electrical - MIL ON/DTC's Set By Various Control Modules
08-07-30-035B
11/01/2010
A/T - Water Or Coolant Contamination Information
05-06-04-022G
10/27/2010
Fuel System - TOP TIER Detergent Gasoline (Canada)
10-08-44-003B
10/13/2010
Audio - Buzz Noise When Using Bluetooth(R)
10023D
09/16/2010
Recall - Loss Of Power Steering Assist
00-08-48-005D
09/10/2010
Body - Vehicle Glass Distortion Information
04-08-50-006D
09/09/2010
Interior - Seat Cover Wrinkle/Crease/Burn Info
10-08-98-002
08/06/2010
Body - Drilling High Strength Steel Using CryoCobalt(R)
06-08-50-005D
07/23/2010
Interior - Seat Cushion Cover Loose
10-03-16-001
07/19/2010
TPMS System - Service And Re-Learning Sensor IDs
03-08-98-002B
06/30/2010
Body - Squeeze Type Resistance Spot Welding/Equipment
07-06-04-019D
06/28/2010
Electrical - Intermittent MIL/DTC P2138/Reduced Power
99-09-40-005F
06/23/2010
Restraints - Extender Availability For Seat Belt
06-02-32-002D
06/17/2010
Steering - Electric Power Steering (EPS) Characteristics
06-03-10-010A
06/09/2010
Wheels - Changing Procedures/Precautions
05-03-10-006D
06/02/2010
Tires/Wheels - Wheel Squeak Noise
06-07-30-004G
05/27/2010
A/T - Various Concerns With Shifter And/Or Ignition Key
08-06-04-033D
05/07/2010
08-06-04-033D - BULLETIN CANCELLATION NOTIFICATION
09-08-50-008B
05/03/2010
Restraints - Air Bag Lamp ON/DTC B0081 71 Set
09-03-16-002A
04/27/2010
Tire Pressure Monitor - TPM System Message/Service Tips
05-03-10-003F
04/27/2010
Tires/Wheels - Low Tire/Leaking Cast Aluminum Wheels
04-03-10-001F
04/27/2010
Tires/Wheels - Tire Puncture Repair Procedures
07-03-16-004C
04/26/2010
Tire Pressure Monitor - TPM System Overview
06-08-44-012E
04/20/2010
Navigation System - Software/DVD Update Program
10-08-110-001
03/30/2010
Interior - Proper Use of Floor Mats
NHTSA10V073000
03/01/2010
Recall 10V073000: Power Steering Motor Replacement
08-08-64-011A
02/26/2010
Mirrors - Heated Mirrors, Defrosting Time
00-07-30-009D
02/24/2010
A/T - Goodwrench Transmission Replacement
06-08-46-005B
02/11/2010
OnStar(R) - Availability for Hearing Impaired
10-08-46-001
01/27/2010
Audio - Radio Does Not Mute Enough When Using OnStar(R)
09-08-52-004A
01/08/2010
Keyless System - Remote Start Transmitter Diagnostic Tip
09-03-10-017
12/17/2009
Wheels/Tires - Replacement Wheel Weight Information
09-08-46-004A
12/17/2009
OnStar(R) - Generation 8 Modules Inop./Battery Discharge
09-08-58-003
12/10/2009
Body - Wind Noise From Door Glass/B-Pillar/Sunroof
09-08-49-018
11/20/2009
Interior - Instrument Panel Compartment Bin Inop.
09-08-47-002
11/17/2009
Body Controls - BCM Cross Platform Functionality
09-01-39-006A
11/11/2009
09-01-39-006A - END OF INFORMATION NEED
09-08-52-002A
11/11/2009
09-08-52-002A - END OF INFORMATION NEED
06-09-41-004J
11/06/2009
Interior/Restraints - R/H Air Bag Not Flush With Dash
09-00-89-025A
10/26/2009
Keyless Start - 2-Way Advanced Remote Start
09-09-41-003A
10/23/2009
09-09-41-003A - BULLETIN CANCELLATION NOTIFICATION
09-08-44-005B
10/21/2009
09-08-44-005B - END OF INFORMATION NEED
05-07-30-016C
10/07/2009
A/T Controls -Transmission Control Module Information
06-08-111-004B
09/25/2009
06-08-111-004B - BULLETIN CANCELLATION NOTIFICATION
09-05-25-003
09/21/2009
Brakes - Brake Pedal Spongy/Increased Pedal Travel
09-08-48-006
09/18/2009
Body - Stain/Film On Windshield Glass Perimeter
06-02-32-013B
08/07/2009
Steering - Power Steering Pump Replacement Tips
07-02-32-007B
08/06/2009
Steering - Power Steering Diagnostic Tips
99-08-64-016C
07/29/2009
Body - Maintaining Exterior Weatherstrip Appearance
07-08-46-002D
07/29/2009
Audio System - Noise When Using OnStar(R)
07-06-01-016B
07/27/2009
Engine - Noise/Damage Oil Filter Application Importance
08-06-01-008A
07/27/2009
Engine - Drive Belt Misalignment Diagnostics
08-03-10-004A
07/24/2009
Wheels/Tires - Accessory Wheel And Tire Information
09-06-93-004
07/21/2009
Engine Controls - MIL ON/DTC P0299/P0234 Set
09-08-64-010A
07/20/2009
09-08-64-010A - END OF NEED FOR INFORMATION
09-09-41-004
06/23/2009
Instrument Panel - Air Bag Indicator Lamp ON
05-08-51-008C
06/22/2009
Body - Bumps or Rust Colored Spots in Paint
08-08-42-005B
06/18/2009
Lighting - Headlamp Warranty Replacement Guideline
09041A
06/11/2009
Recall - A/T Shift Cable Adjustment Clip Inspection
08-08-64-009A
06/08/2009
Body - Outside Rear View Mirror Difficult to Adjust
07-09-40-002A
06/04/2009
Restraints - Seat Belt Latch Stop Button Availability
09-08-64-020
05/20/2009
Body - Front Door Glass Loose/Wind Noise/Water Leaks
02-08-44-007D
05/12/2009
OnStar(R) - Negative Impact of Cloth/Vinyl Roofs
09-07-30-009A
05/01/2009
A/T - Will Not Move/No Reverse/Slips
08-03-10-005A
03/31/2009
Wheels/Tires - Chrome/Steel Valve Stem Cap Precautions
00-05-22-002L
03/26/2009
Brakes- Disc Brake Warranty Service And Procedures
06-08-67-019B
03/25/2009
Body - Headliner Wet At Center Map Light
09-08-48-002A
03/19/2009
Body - Marks/Stains on Windshield When Wet
08-08-44-010F
03/09/2009
Navigation Radio - Diagnostic Tips
NHTSA09V073000
03/06/2009
Recall 09V073000: A/T Shift Cable Adjustment Clip
02-08-98-002C
02/03/2009
Body - Hem Flange Rust Repair Information
09-06-05-001
01/30/2009
Exhaust System - Sulfur Odor Explanation
01-07-30-036H
01/29/2009
A/T Control - DTC P0756 Diagnostic Tips
07-08-98-001A
01/28/2009
Body - Non-Approval of Clipping For Collision Repair
09-08-67-001
01/06/2009
Body - Rattling Noise From The Sunroof Area
01-06-01-011E
12/18/2008
Gasoline Engine - Oil Consumption Guidelines
08-08-44-032
12/10/2008
Audio System - iPod(R)/iPhone(R) Won't Connect To Radio
07-03-10-013D
11/24/2008
Wheels/Tires - Vibration While Driving
08259A
11/06/2008
Campaign - Inoperative OnStar(R) System
08-06-03-009A
10/29/2008
Electrical - Reducing Intermittent Electrical Concerns
01-07-30-032E
09/29/2008
A/T - 4T65E Fluid Leaking From A/T Vent
08-08-46-006
09/25/2008
Audio System - XM(R) Terrestrial Repeater Changes
05-03-10-005D
09/11/2008
Wheels/Tires - Upsized Wheel/Tire Characteristics
07-03-10-016C
08/29/2008
Wheels/Tires - Required Label When Changing Wheels/Tires
08-07-30-039
08/21/2008
A/T Controls - Service Fast Learn Adapts Characteristics
08-08-126-001
08/15/2008
Navigation Radio - XM NAV(R) Traffic Coverage Areas
08-08-44-026
08/11/2008
Audio System - Refurbishing Radio Faceplates/*****
02-06-03-008D
07/21/2008
Charging System - Low Voltage Display/Battery Discharged
08-08-44-024
06/27/2008
Voice Recognition System - Won't Recognize Bluetooth(R)
05-00-89-072B
06/17/2008
Engine/Fuel System - Oil/Fuel Additive Information
08-03-10-007
05/16/2008
Tires - Minimizing Damage to TPM Sensors
01-07-30-010C
05/12/2008
A/T - Torque Converter Replacement Information
08-03-16-003
05/12/2008
Tire Monitor System - TPM Sensor Information
02-06-03-009C
04/17/2008
Electrical - Battery Charging Tips/Recommendations
RockAuto
May 29th, 2013 2:29 PM
RockAuto
July 6th, 2012 12:02 PM
billnet
July 14th, 2010 6:55 PM
Stingray
February 22nd, 2007 12:08 AM
Quick Reply: Updated TSB listings ONLY
