Brake Controller Battery Hookup
Old January 13th, 2010, 8:03 AM
SabrToothSqrl's Avatar
Default Brake Controller Battery Hookup
I thought I read in the manual I have to connect a wire under the dash to enable the power to the factory brake controller?
If I have the factory brake controller in my 09 tahoe, do I still have to do that?
We put new axles on my boat trailer this winter, I haven't wired the trailer yet (just wanted to get the axles on, wiring + lights this spring) when its NOT 20 degrees outside...
Once I have the trailer all wired up, 7 pin, do I just connect it, or do I have to pop the hood and hook up that wire?
seems stupid GM wouldn't just connect that wire, what lawyer came up w/that?
thanks!
Old January 13th, 2010, 8:56 AM
jeffbco's Avatar
thanks!
I've not seen anything about an additional wire hook-up. Once you plug in the 7 pin you should see some indication on the DIC that the trailer is hooked up and that the electrical brakes are active. I haven't tried it yet though.
Old January 15th, 2010, 5:23 PM
I've got the trailer brake controller but haven't read about it yet. I did notice a wire w/ a ring terminal on it taped to the underhood harness next to the fuse box. I did wonder about what it was for.
Old January 16th, 2010, 5:22 AM
Ride of the Month
May 2009
mudmaniac's Avatar
I didn't know they offered a factory controller. I would think that if it came with one it would be wired. I installed one on my 06 silverado and had to install the factory harness that was provided with the tow package, when I installed one in my 07 Escalade the wiring was there and it needed to be connected to the power supply under the hood.
Old January 19th, 2010, 8:04 AM
I will look when I get to it this summer i guess... I still need to wire the brakes on the trailer as well... thanks.
Old January 19th, 2010, 10:48 AM
I think that extra terminal is to get AUX 12v output to the rear harness...
Old January 19th, 2010, 11:04 AM
Default power
which is for charging the battery on the brake system, correct? which is required when towing a trailer w/electric brakes... so why do they leave the stupid thing unpluged?
Old January 19th, 2010, 11:16 AM
One less thing to short out...
in2pro
May 29th, 2008 11:22 AM
mak90
September 13th, 2007 5:18 PM
bigmac
April 12th, 2007 1:39 PM
rv21350
October 6th, 2006 12:35 PM
deveng
Sonic (Aveo)
May 14th, 2006 10:56 AM
Quick Reply: Brake Controller Battery Hookup
