Notices
temp gauge moving
Old July 15th, 2012, 4:42 PM
99tahoeinwv's Avatar
Default temp gauge moving
I recently noticed temp gauge moving up and down. Added coolant as it was low. For several weeks temp gauge stayed at normal.. yesterday i noticed it moving again. I pulled radiator cap and its brownish around cap... Im afraid its a head gasket but want to know if it could possibly or hopefully be something else. Any thoughts? Thanks for ur help
Old July 15th, 2012, 4:44 PM
kevinkpk's Avatar
Might be, if it is the lower intake gasket, check for oil loss into the cooling system.
Old July 15th, 2012, 4:57 PM
Kevin how would i check for that?
Old July 15th, 2012, 5:04 PM
kevinkpk's Avatar
Pull the dipstick, If it is high, then you have that issue.
Old July 15th, 2012, 6:09 PM
Checked oil. Actually looked a little low. Then checked coolant and it was really low. I added water and it took 3 mason jars of water to fill radiator.... I have no experience in dealing with this but if antifreeze is leaking into oil or vice versa shouldnt one of them have reallg high levels?
Old July 15th, 2012, 6:23 PM
kevinkpk's Avatar
You will have to drive it, AND check the dipstick often. If the coolent is getting into the oil system, you will know it after a couple weeks. Less any external leaks.
Old July 16th, 2012, 11:06 AM
If the oil looks milky you know for sure... a compression check may also help identify where the leak is
Old July 19th, 2012, 9:57 PM
UPDATE... I drained the radiator tonight and put prestone flush in it. Ran it through and drained it. It was brown... But i realized i had added coolant a few weeks ago and that might have discolored it.. so i flushed it with water again and it still came out brown... Does that make sense? I did add bars sealant and then antifreeze and water.. ran it for over 20 mins and it never moved...
Old July 20th, 2012, 9:00 AM
kevinkpk's Avatar
You're probably ok. Barrs leak is brown, but one can shouldn't change the color brown.
Old July 20th, 2012, 9:25 AM
SabrToothSqrl's Avatar
Default well..
head gasket would mean that coolant is being burnt off through the exhaust. so you may not notice a leak, but you could see white smoke out the tail pipe...
but hopefully that isn't the issue.
Quick Reply: temp gauge moving
