Notices
water keeps frying the blower motor regulator
Old September 11th, 2015, 5:42 PM
Splathapy's Avatar
Default water keeps frying the blower motor regulator
hello,
i can seem to find where the water is getting into the ac box on my 2005 1500 2wd chevy suburban, i have checked to make sure the drain is not pluged, i have even ran a fiber optic camera in there and can not see any water, also i left the blower motor regulator out and the gf decided to take it threw the car wash and no water came out, however when she turned the car hard a bunch of water came out.(like someone dumping a cup of water).also i have replaced the windshield because it had a small crack in it to make sure that is not it. totally frustrated with this any help would be greatly appreciated.
thanks
joel
Old September 11th, 2015, 7:55 PM
pretty sure there is a tsb from gm engineering to fix this.
Old September 11th, 2015, 8:42 PM
Splathapy's Avatar
hello,
thanks for reply , i have been unable to find one. i have looked,should i take it to the dealer and ask, i am sure it being a 2005 the recall is out of date
thanks
joel
Old September 12th, 2015, 8:29 AM
a tsb is not a recall. if you took it to the dealer you would have to pay for the repair.
Old September 15th, 2015, 9:44 AM
Official GM Rep
Originally Posted by Splathapy
hello,
thanks
joel
Hello Splathapy,
We apologize that your Suburban has been experiencing this water concern, and can certainly understand how frustrating this situation must be. We are available and happy to assist in the best way possible. Please send us a private message with your VIN, mileage, full contact information and preferred dealership. We look forward to your response!
Have a wonderful day,
Helen
Chevrolet Customer Care
caasperlee6468 (August 9th, 2022)
Old August 9th, 2022, 5:12 PM
caasperlee6468's Avatar
Default 2005 Chevy Silverado water leak into heater blower
I have the same problem, this has blown 3 blower motors and I still cannot find the leak into the fresh air intake. I have replaced the foam padding under the cowl and have caulked the access panel above the fresh air intake. What was the repair that GM came up with?
Old August 10th, 2022, 8:43 AM
repairman54's Avatar
Make sure the cowl drains on the ends are not plugged so the cowl area itself is draining.
Old August 10th, 2022, 5:04 PM
Default Water into fresh air intake.
That was one of the first things that was checked before I dove deeper into the problem. Thank you.
Old January 4th, 2023, 6:13 PM
BerserkerJack's Avatar
What "Drain" are we talkin that might be "plugged"?
Old January 4th, 2023, 6:15 PM
Forgive be, I ain't smart. What is a "tsb"?
Quick Reply: water keeps frying the blower motor regulator
