What battery are you using in your '07 Tahoe?
So about 3 weeks ago, my battery died in my Tahoe, due to my daughter playing in the driver's seat and leaving the parking lights on. Almost more than a year ago I was told I needed to replace the battery. I never replaced it. It starts the SUV just fine, no hesitation. So I recently went looking around just to see if I could find a DieHard replacement, NO LUCK! I went to Wal-Mart, NO LUCK! I think I found a direct replacement from Interstate, but the website was a little shady, and I didn't want to get ripped off. So my question to those who have replaced the OEM battery in their 07 Tahoes, what battery are you currently using? Part numbers please! I'm looking for a battery with a ton of CCA'S that will fit in the stock battery holder properly. I've noticed the battery holder has sort of a "long notched" area where the battery holder fits into. Thanks in advance!
Ride of the Month
August 2009
August 2009
Get a yellow top optima battery. It will be the last battery you will need for a VERY VERY VERY long time. I've had the same battery in three different trucks now spanning over seven years. The battery has completely died three times(due to excessive stereo use and lights being left on) and after a jump it recharges itself and it's been running as good as it's ever been. HIGHLY HIGHLY recommended. Trust me, it's worth the money. Plus you can find a good deal on one anywhere.
Deez
Deez
I got mine at Sam's Club. Just looked up the OEM replacement and it fit fine. It's a PITA to have to remove a brace just to get the old one out.
Considered an Optima but almost three times the price was a deal breaker. Not sure I'd have the truck long enuf to pay off. Plus I'm not sure this new charging system is good for battery longevity.
Basically it only charges when needed and lets the battery run down a lot more than the old system did. If you look at the voltmeter, at times it be fairly low and at other times it's high. Supposedly saves gas cuz the alternator is not loaded all of the time. If it does, it's a miniscule amount.
Professional Mechanic
I replaced mine with a AC Delco,since we get most of our parts from a company called "Delcoline" and we are a acdelco TSS shop they warrentied it and it cost me nothing
1 Post
If you're looking for a starting battery, and not a deep cycle battery battery, take a look at an Optima Red Top. This is a starting battery, like the one you're replacing. It's not a deep cycle battery as the Yellow Top is. It has a higher CCA than the Yellow Top. I used a pair of Red Tops for years in a Dodge Ram Turbodiesel. On a winter morning, the grid heaters used at prestart pulled 180 amps for 45 seconds, and it started like a charm. At 5 years, they were still doing fine when I parted with that animal truck.
I have been reading about all the issues people are having with batteries on the 2007 and 2008 Tahoe and Suburbans. We have an '07 Tahoe LTZ and the battery already has a bad cell. I decided to replace it with an Optima Yellow Top becuase of the way the charging system works. It tends to let the battery run down a bit before the alternator will kick in to charge. With the accecories on the LTZ and Z71 models (such as Nav, DVD, etc), that is really hard on a typical battery. A deep cell battery like the Yellow Top is much more resistant to constantly discharging and recharging.
I wanted to point out that although the Optima website doesn't list a compatable battery for these vehicles, the D35 (part number 8040-218) is a perfect fit and is the only one that has the terminals on the correct side and doesn't require any modification.
D35
D35, will keep that in mind. Mine's under warrenty until 5 yr 60,000.... they have already covered the battery once for me... after that's up I will get a yellow topper... I had a red in my last Tahoe, loved it. lasted 6 years not a problem once.
