whining sound when slowing down in my 07 Tahoe 4x4
So I've been having this whining sound when slowing down to a stop, its relative to my speed. Been doing research and possible causes are low diff. fluid/no diff. fluid. If this was the case, would i be able to switch from 2high to any other setting? This is the case with me, I can still switch from 2 high to auto to 4 high, did not try 4 low. Any suggestions, im not very saavy with checking the fluid levels myself. Most likely bring it to the dealer.
I did not try that, but I will tomorrow. What if it does not make the whine while in neutral, what do you suspect it means? Thanks for the advice!
UPDATE: Shark, I tried it this morning and no change in the noise whatsoever. Guess its time for the dealer, AGAIN!
aubiexx
December 1st, 2013 7:58 AM
flynhayn
Silverado & Fullsize Pick-ups
July 22nd, 2011 9:35 AM
peedeefish
March 15th, 2010 2:43 PM
