Won't crank
Won't crank
Hello friends, the burban on a rainy day shut down at about 25mph, turned over but would not start, pushed it the last 1/2 mile home, tried to start, turned over, battery went dead, replaced the battery with a new one, dash lights up, wont crank, tested starter, passed, replaced starter, dash lights up and starter engages but wont turn over. what do i check now? thank you
I found a fuel leak, its behind and under the alternator and its a big leak, i think this is my original problem that cause the burban to stop running, but this doesnt explain why it will now not turn over, any advice on the fule leak is welcomed, hard to see exactly where its coming from cause its a big leak and the alternator is blocking my view
