Wouldn't start on a good battery
Here's a weird one. 2001 Tahoe. 65,000 miles
It a new truck to me. Drove it 2,000 miles then last week noticed it was struggling a bit to start. Had the battery tested at Advance Auto and he said it sounded fine. The charge was a little low so I bought a charger and put it on overnight. The charger went about 12 hours (10 amp) and said it was done.
All the list worked that day as I cleaned it but never started it. The next day I tired to start it but it just clicked. After that none of the lights or electrical would even work. My battery tested said it had a full charge.
A few neighbors and I were all perplexed. How could this be?
Another neighbor showed up and wanted to listen and this time it started right up.
I don't want it to strand me here but I also don't know where to start looking for a problem? Any suggestions?
Welcome to the forum.
Sounds like a bad connection on the main battery cables. Check both ends. There's also a big fuse and I think from reading another post that it's on the firewall on psgr side. in2pro can confirm.
We checked everything. Cables were on tight. I'll check that fuse, but I can't imagine it's the culprit. It can't be blown because it starts now without doing anything to it.
Perhaps it was loose, but we didn't touch anything over there before it miraculously decided to start.
Thanks for the help.
:chug:
I wish I could write it off as a dead battery. I had it tested like I said and they said it was good, just slightly low. They'd try to sell me one if it was even close.
If it was dead, it wouldn't have started later that day. And we've been driving it all day since then (multiple starts) without a problem.
I will clean the cables to make sure.
Check the wires to the alternator or even get the alternator checked at autozone. When cleaning the terminals use dialectic grease! Using anti-cease and other lubricants will be your best friend later down the road...
I heard the alternator can get corroded, but I'm not sure how to check that.
I'll clean the terminal posts and wires. I'm just hoping this doesn't happen again.
I agree with post above, short of it being a starter going bad the most logical suspect would be a poor connection.
The starter is not getting the amperage it needs, you may be able to see 12+ volts at every battery point connection but if the connection is corroded or broken down from excess current draw it won't provide the power needed to turn the starter over...
Check the cables for any hard or stiff areas where the corrosion could be inside the cable jacket, pay particular attention to any areas that have nicks or cuts..
