2000 Tahoe brake question
#22
#24
once i get around to all this, ill try everything. i did some preliminary troubleshooting and found that the wire that connects to the brake fluid reservoir wasnt plugged in. i plugged ut in and my parking brake light stays lit even when not set, but setting it makes the light flash. if i unplug that connector the light is off and when i set the parking brake the light comes on and flashes. i rear that could mean the fluid level is low, but my brake fluid level is only about half an inch below the max line. i think that sensor is bad, so im gonna leave that unplugged. i tested some other stuff, and my calipers do move when the brakes are pushed, and the pedal holds pressure like it should. im gonna replace the pads and rotors on the front cuz ive already bought them, and probably the same on the rear as well as bleed the brakes and make sure the calipers move as they should (they squeak right now).
now if i could just get rid of the minor engine miss like stutter when idle while warmed up to normal temp, id be so happy .
