Last edit by: IB Advertising
- Chevrolet Silverado GMT800, GMT900, and K2XX How to Replace Dome Light
2001 interior lights
I have an 01 Suburban. The interior dome lights don't work when the doors open nor when the dome override switch is pushed. Also when you roll the dimmer switch all the way up the lights do no come either. Please help.
Welcome to the forum. Check the 15A CTSY LP fuse in the underhood junction block. There should be battery voltage. After that, try replacing the INADV PWR relay and CTSY LP relay in the I/P fuse block. Either one can knock out the courtesy lighting.
On my 99, I have to roll the dimmer switch up and down real quick for a while before the lights come on. Over time the switch became erratic and doesn't always work. Check the switch.
jamesq
Silverado & Fullsize Pick-ups
November 2nd, 2010 6:02 AM
skdevore
August 26th, 2009 10:18 PM
