#4 Cylinder Misfire - Chevrolet Forum - Chevy Enthusiasts Forums
#4 Cylinder Misfire
dogman1313's Avatar
November 14th, 2011, 3:08 PM   #1
#4 Cylinder Misfire
I have a misfire on the #4 cylinder, I have changed the Spark Plugs, The Plug Wires, The Rotor & Distributor Cap. But I still seem to have the miss. If it is the #4 injector, how do I replace it. I swapped plug wires, & changed the Spark plug, what else could it be ? I forgot to mention it is a 1999 Suburban 4x4
thanks in Advance
kevinkpk's Avatar
November 14th, 2011, 3:41 PM   #2
Is it have a check engine light? If so, can you read the code?
dogman1313's Avatar
November 14th, 2011, 3:49 PM   #3
Yes it has a code & you can feel the misfire , the code is po304 which I believe is a #4 cylinder misfire.
kevinkpk's Avatar
November 14th, 2011, 3:56 PM   #4
PO0300 is misfire, so 304 indicates to me #4. What did the plug(s) look like?
NGK Spark Plugs USA
dogman1313's Avatar
November 14th, 2011, 4:13 PM   #5
The # 4 was kinda white, w/ a little black, it wasn't wet, I just took an old wire & replace the new one, I changed the new plug out with another new one but still have the misfire. I have an AutoEnginiuty program that I use, plus a generic scanner & they say the same, but what could be causining the misfire on #4?
kevinkpk's Avatar
November 14th, 2011, 4:20 PM   #6
White deposit, with black. I'd say injector.
dogman1313's Avatar
November 14th, 2011, 4:25 PM   #7
how do you replace the injector ?
kevinkpk's Avatar
November 14th, 2011, 4:42 PM   #8
Gotta remove the intake, that also means more than just injectors, but also gaskets. I looked on you tube for something to help, but nothing. I'd also add, replace all 8. You "may" have 1 bad, but going to this level, not replacing all of them just a matter of time befoer you'll be back into it.
armystrong928's Avatar
October 24th, 2012, 1:48 PM   #9
Cold also be o2 sensors mine is doing it too. But my plugs are a rust color.
Bruin4LB's Avatar
September 22nd, 2014, 11:22 AM   #10
Posted By: dogman1313 I have a misfire on the #4 cylinder, I have changed the Spark Plugs, The Plug Wires, The Rotor & Distributor Cap. But I still seem to have the miss. If it is the #4 injector, how do I replace it. I swapped plug wires, & changed the Spark plug, what else could it be ? I forgot to mention it is a 1999 Suburban 4x4
thanks in Advance
So my P0304 message for piston 4 misfire with Traction Control & Service Stabilitrak message led to Collapsed Lifters on the right hand side. This only uncovered after I replaced spark plugs, spark plug wire, swapped ignitors, performed fuel injection cleaning. Condition worsened while I was on vacation. I started receiving a P1175 message, constant engine clicking noise, in addition to consuming 2 qts of oil. In the end, took it to dealer after local mechanics wanted to replace the entire engine. Replaced Collapsed Lifters on the both sides and was good as new.
Tags
Sponsors
