96 Tahoe steering problem
Old January 8th, 2014, 3:58 AM
jhatcher1's Avatar
Default 96 Tahoe steering problem
I have a 96 Tahoe, for some time now when you turn the steering wheel it would make a quick squeeking noise. I have been running oversize tires on it for a couple of months with no problems. Now when you turn the steering wheel hard to the left or right it acts like it has four flat tires and doesn't want to go? It drives and turns slight turns, its just when you try to turn hard or make a sharp turn like pulling into a parking spot?
Old January 8th, 2014, 4:10 PM
SWHouston's Avatar
Not sure about the squeaking issue, but...
By chance is your ride a 4WD, and, do you have it in 4WD Auto or Hi ?
Old January 8th, 2014, 8:28 PM
seized/tight ball joints. When they dry out or the boots tear and water get in them they don't rotate smoothly.
Old January 8th, 2014, 9:45 PM
Do the 96's have the variable speed sensitive steering? if so it could be the sensor the the power steering assist going out....
Old January 9th, 2014, 4:01 AM
jhatcher1's Avatar
I took the dash off recently to install a new stereo so maybe I hit the 4 wheel drive button or something? It does sound maybe to me like the ball joints...not sure but I will check all of these things. Thanks for the help!
scot
June 22nd, 2021 12:26 PM
bobbygrady
Silverado & Fullsize Pick-ups
August 14th, 2013 8:57 AM
w002mia
June 29th, 2013 3:27 AM
w002mia
March 18th, 2013 11:42 AM
cyberrkatz
January 31st, 2011 8:54 AM
Quick Reply: 96 Tahoe steering problem
