rear semi-floating axle bearings
If you need to replace your axle bearings and seals, O'Reilly Auto Parts will loan a slidehammer and bearing removal attachment. You get your money back when you return the equipment.
I have a bad seal on the LR wheel and it is slinging 75-90w oil all over the brake shoes. I think my bearing may have run a little dry, it makes a noise. At 170K miles, I'm replacing both sides
bebetz
May 31st, 2010 5:16 PM
robbiesmechanic
Engine Building & Overhauling
May 25th, 2009 6:57 AM
