2003 tracker
2003 tracker
my 2003 tracker shakes at idle....and shakes when you come to a stop....i changed the motor mounts and trans mount...I also cleaned the idle control valve....any ideas
egr valve
The EGR (exhaust gas recirculation) valve, if it's stuck open can cause the excessive shaking. I replaced plugs, IAC valve and mine still shook (1999 model). I have a new EGR valve to try next. I also have a 2003, and it doesn't shake but it idles faster. I may just increase the idle speed on the '99 and see if that helps.
MonmouthCtyAntz
March 9th, 2010 9:50 AM
