2004Tracker towing behind RV
Tracker Towing
The 4 wheel drive Tracker can be towed with all 4 wheels on the ground. It will require a base plate and a tow bar. (Blue Ox makes both). You put the key in the accessory position and the 4 wheel drive transfer shifter in nutural.
You will also need a brake light kit.
Jetty
Jetty
Jetty
Jetty
I have done all that But when I leave the car in park and put the transfer case in neutral the back tires locked up? what am I doing wrong???? Please advise. Thank you
Tracker Towing
If you indeed have the transfer case in neutral, it would be impossible for the rear wheels to be engaged.
Try it without the Tracker being connected to your RV. With the engine running, put the Transfer case in neutral: Put the auto shifter in drive: Your Tracker should not be able to move if the Transfer case is truly in neural. If it does move, then I am lost.
I have been pulling my Tracker for several years and never had your problem.
Jetty
Jetty
Jetty
Jetty
Thank you very much I will try it before I take off next
Hapy1Luky2
Equinox
September 23rd, 2011 10:51 PM
Nyron
Silverado & Fullsize Pick-ups
June 28th, 2010 10:55 AM
