compatibility between vitara / tracker
I have a 2003 tracker and the I need a few parts for it,
i found a parts truck but its a 2001 grand vitara. I know there are many things the same between the two but the body is a bit different in some areas.
Will the back tailgate /door work from the vitara for my tracker ?
and also the carrier housing in the front diff (i dont need the gears inside only housing) Iknow the gears wouldnt work because the vitara is auto and v6 and my tracker is manual and 4 cyl.
thanks so much !!
CHEVY
TRACKER 2003
4X4
4 CYL
4 DOOR
STANDARD
thanks so much !!
CHEVY
TRACKER 2003
4X4
4 CYL
4 DOOR
STANDARD
My Suzuky dealer will sell me engine parts without hesitation for my tracker.
If I ask for a body part, I must take the piece for comparison.
Maybe your best bet is to find someone with a 2001 Grand Vitara and ask him to let you have a look. An used car dealership might be a good place to look. Pretend you are interested in buying the Vitara and take a look at the doors and housing. I did that before I went looking for a used jack for my tracker-
