Popping noise
New to the forum here, but I know what your issue is, your sway bar end links are a ball and socket design. When you turn or hit bumps, the ball is popping out of the socket and then back in. When you look under your Tracker, they look fine because they pop back in the socket. Long story short, you need to replace your sway bar end links. Hope this helps !
