TrailBlazer 2002-2009
The TrailBlazer, originally introduced as an upscale Blazer, was produced from 2002 to 2008 with a powerful I6 engine and with a monster V8 offered in the Trailblazer SS
2002 TB died and wont start
Old February 4th, 2007, 8:01 PM
kennige's Avatar
Default 2002 TB died and wont start
My 2002 trailblazer died nin the driveway and wont start or shift out of park. It was running fine when it started torun rough. The began fluctuating around 50 mph and then it died.All of the accessories work fine, but when you turn the key to start it nothing happens. The turn signals do not work and none of the gauges work. The shift indicator light is the only thing that come on. I found the release on the console to shift to nuetral so i could move it to the street for the wrecker, but i want to know if there is anything else i can do.
Thanks
Old February 8th, 2007, 1:05 AM
RonH's Avatar
Default RE: 2002 TB died and wont start
Have your checked you battery connection?
Old February 8th, 2007, 4:11 PM
rbarrios's Avatar
if its an AC delco battery- check the + terminal. been known to leak and eventually have the terminal break off or cause little power to get thru.....
Old July 24th, 2008, 2:00 PM
02trailblazeryyc's Avatar
I had the exact issue with my 2002 trailblazer. The problem was the ignition switch had to be replaced. I'm actually on my third ignition switch so i'm thinking this should be a recall, as I see this seems to be a common problem.
Steelman512
April 5th, 2019 8:04 AM
aabner75
February 25th, 2014 4:03 PM
kbest.1990
February 2nd, 2012 4:53 AM
shouldaboughtaford
Silverado & Fullsize Pick-ups
July 20th, 2011 7:37 PM
mason32
April 10th, 2010 6:43 AM
Quick Reply: 2002 TB died and wont start
