TrailBlazer 2002-2009
The TrailBlazer, originally introduced as an upscale Blazer, was produced from 2002 to 2008 with a powerful I6 engine and with a monster V8 offered in the Trailblazer SS
05 trailblazer gear is stuck in park
Old March 10th, 2009, 10:21 AM
romanlu's Avatar
Default 05 trailblazer gear is stuck in park
my 05 trailblazer is stuck in park. what is the problem?? please help husband is deployed and wondering if its going to cost me and arm and leg to repair
Old March 10th, 2009, 3:15 PM
rbarrios's Avatar
please let us know if your battery is dead.
Could be the solenoid in the shifter has malfunctioned.
If im not mistaken- the manual also has a procedure on getting the vehicle out of PARK in case the battery has failed.
in case the battery has not failed---
You may be able to shift it into neutral- and start the vehicle from there....
at least youll be able to drive it.
If you follow the procedure in the manual and still cant shift it-- then its probably related to some damaged linkage...
Old July 8th, 2009, 3:07 PM
shepdog25's Avatar
If you're parked on an incline without the parking brake on you migth have to push on the car to relief pressure on the trans
Old July 8th, 2009, 5:18 PM
rbarrios's Avatar
she never came back....
Old July 8th, 2009, 5:58 PM
G&b
G&b's Avatar
Default 03 trail blazer starts good but when hot cut off won't start back until cold please
Already check ground fuse relay box good, install a new swicth !!!! What can it be! Please help me! Fuel pump is good
Old July 8th, 2009, 7:55 PM
EvansBlue's Avatar
Make a new thread please.
mrpurplehawk
June 23rd, 2014 10:59 PM
mak1na
Express & G-Series Vans
April 23rd, 2013 11:32 AM
BigblackHo3
April 5th, 2013 8:54 AM
bdm408
Silverado & Fullsize Pick-ups
September 11th, 2008 8:55 PM
bdm408
September 7th, 2008 6:24 PM
Quick Reply: 05 trailblazer gear is stuck in park
