TrailBlazer 2002-2009
The TrailBlazer, originally introduced as an upscale Blazer, was produced from 2002 to 2008 with a powerful I6 engine and with a monster V8 offered in the Trailblazer SS
New battery, still won't start...
Old September 23rd, 2016, 7:45 PM
Whiskey_Sauer's Avatar
Default New battery, still won't start...
The starter is turning, sounds kinda like the engine is as well, but it's turning slowly and won't crank. Is this a starter issue or related to my transmission woes (suddenly and completely failed with no warning lights)?
Old September 24th, 2016, 12:57 AM
Could be the battery needs a good charge or a case of loose or corroded battery cables. They need to be checked at both ends.
Old September 24th, 2016, 8:56 AM
New battery. It's literally not even 2 weeks old from the date of manufacture. This starting issue is also very sudden. The day the transmission failed and the tow truck dropped it off in my driveway, it wouldn't start, same symptoms.
Old September 24th, 2016, 12:33 PM
oilcan9761's Avatar
was it running after the tranny failed and you pulled over to the side of the road?
Old September 24th, 2016, 12:40 PM
Yes. Running great.
Old September 24th, 2016, 2:08 PM
oilcan9761's Avatar
contact the towing co. they may have unhooked something before they towed it ? or possibly pulled a fuse !!!
Old September 24th, 2016, 2:13 PM
What ever would they have done that for? He put it in neutral, never had any opportunity to access either fuse block (one in the engine compartment, one under the rear driver side seat).
Old September 24th, 2016, 4:03 PM
oilcan9761's Avatar
just a thought
