2008 TB Temp Gauge and A/C issue
Having issues with the Temp Gauge reading 100 degrees continuously one session, and then read normal temps the very next drive session or next day. Also, The A/C will not work sometimes. The light indicator is on, the fan is blowing, but the compressor will not energize. Then suddenly, for no apparent reason, it starts to work normally. Someone please help identify these Gremlins.
hello
i am having the same problem with a/c shutting off along with temp gauge drops off.
how ever when i disconnect battery and re-connect battery " does'nt matter 5 sec or 5 hrs " everything works normal. may last a day or weeks ! anybody had and resolved this issue ?
Mine ended up being the thermostat held open. The gauge would never go past 100 degrees. $420 later, I have a new thermostat and no more issues. AC works great as well. I think it shuts off the AC as a safety measure.
thanks, youkinda confirmed that. when the problem first started i was getting a eng cooling temp fault. just 2 days ago i got a thermostat open fault on the pcu. thanks for the feed back!!
skategranger
February 18th, 2013 2:38 PM
Tennesseestorms
February 14th, 2010 4:56 PM
Mauler
Silverado & Fullsize Pick-ups
March 2nd, 2009 6:40 PM
